ymzhang Tue, 04/17/2007 - 10:49
after loading the IOS-S281-CLI.pkg file into your router, use 'show ip ips signature' command to find out what signature level the router is running. It should show 'Cisco SDF release version S281.0' if the package loaded correctly.
If this is the case, you might hit some minor errors and you can ignore the message you got.
-Chris
ymzhang Tue, 04/17/2007 - 11:21
-Chris
