7206vxr NPE-300
Answered Question
Apr 16th, 2007
What is the maximum media packets the 7206 can handle per second. We are interfacing our 7206vxr NPE-300 with a Nextone SBC (sound Board Controller) and its causing the CPU on the 7206 to run at 98%.
Correct Answer by pciaccio about 10 years 2 months ago
The attached document will tell you the specs for the router..Please rate....
Correct Answer by mohammedmahmoud about 10 years 2 months ago
Hi there,
Kindly check the following link, but bare in mind that when there is ACL, encryption, compression and QoS configuration and not using CEF, dramatically effects the router performance:
http://www.cisco.com/warp/public/765/tools/quickreference/routerperformance.pdf
HTH,
Mohammed Mahmoud.
Overall Rating: 5 (2 ratings)
