1721 and t1
Answered Question
Apr 16th, 2007
I've a 1721 cisco router and I need to purchase to my ISP (Telefonica Spain) a point to point conection to internet.
What kind of wic have I need to purchase?
best regards
Correct Answer by spremkumar about 10 years 3 months ago
Hi Edgar
since its a point to point (T1) link its limited only to 1.5 Mbps you can make use of that 1.5 Mbps bandwidth alone.
you wont be able to add or remove any channels on this module.
if you want to upgrade the existing bandwidth from 1.5 Mbps then you will have to add up one more module or go with WIC-2T and 2*T1's which can support 2*1.5Mbps ..
regds
Overall Rating: 5 (1 ratings)
edgar-quintana Tue, 04/17/2007 - 00:18
Hw many channels are reserved for a 1t connection? if I add more channels, will this card be enough?
best regards
Anand Narayana Tue, 04/17/2007 - 00:30
  • Silver, 250 points or more
Hi Edgar,
WIC-1T supports maximum of 2Mbps bandwidth.
Correct Answer
spremkumar Tue, 04/17/2007 - 00:32
  • Red, 2250 points or more
Hi Edgar
regds
spremkumar Tue, 04/17/2007 - 00:52
Hi Edgar
do check the link posted in my first post..
regds
