IPX tunnel over IP
Answered Question
Apr 16th, 2007
Need sample config for IPX tunnel over IP (two IPX LAN connected with IP only link).
Correct Answer by Harold Ritter about 9 years 9 months ago
It can be as simple as configuring a GRE tunnel and applying an IPX address on it as follow:
interface Tunnel0
no ip address
ipx network deadbeef
tunnel source xyz
tunnel destination abc
Make sure you include this address under your routing protocol.
Hope this helps,
Overall Rating: 4.8 (3 ratings)
Correct Answer
Harold Ritter Mon, 04/16/2007 - 19:15
interface Tunnel0
no ip address
tunnel source xyz
Hope this helps,
