OSPF
Answered Question
Apr 16th, 2007
My 3560g-24 will allow me to configure router ospf xx but doesn't take me to the next level. However if I configure router eigrp, it takes me to the next level. What could be the problem?
Correct Answer by Harold Ritter about 9 years 10 months ago
Mary,
You can keep 12.2(25)SEE or go to anything more recent but you need to make sure you get one of the following feature set in order to support OSPF:
- ADVANCED IP SERVICES
- IP SERVICES
- IP SERVICES W/O CRYPTO
Hope this helps,
Overall Rating: 5 (2 ratings)
Harold Ritter Mon, 04/16/2007 - 19:02
Mary,
It sounds like you might not have the right feature set. Can you include the output of a "show ver".
s-sheffield Mon, 04/16/2007 - 23:30
I agree
even though the commands are in the show ? output, to be able to use them depends on the type of IOS. I think IPBase lets you do minimal eigrp config (stub) but the IPServices version gives you more L3 functionality so you can use the OSPF sub- commands.
hope this helps
Stu
Harold Ritter Tue, 04/17/2007 - 05:28
The behavior you are seeing is definitely because you are running the IP Base feature set. This feature set will allow you to run EIGRP but not OSPF. Please upgrade to the IP Services feature set so you run OSPF.
Hope this helps,
mlucero Tue, 04/17/2007 - 08:40
I don't have the switch anymore but I can tell you what the IOS that it has is 12.2(25)SEE
I'm going to get it and have to configure OSPF. What version do I need? We do have a smartnet contract.
Thanks for all your help.
-Mary
Correct Answer
Harold Ritter Tue, 04/17/2007 - 09:31
Mary,
- IP SERVICES
Hope this helps,
