04-16-2007 08:34 PM - edited 03-11-2019 03:00 AM
Hi guys,
I have setup a pix 515e with 7.0.(6) I am unable to ping to the internet from the internal hosts. I am able to browse the internet and do DNS lookups. Also the hitcnt does not increment. It always shows up as 0
I have added the following lines to allow icmp through but this does not allow me to ping to the internet. I can ping the external interface of the pix from the internet. Is there something i am not doing right?
access-list in-to-out extended permit icmp object-group internal-lan any log
access-list out-to-in extended permit icmp any any
icmp permit any echo-reply outside
icmp permit any echo outside
icmp permit any outside
icmp permit any inside
Solved! Go to Solution.
04-16-2007 09:45 PM
hello,
by default pix does not allow icmp traffic or any other traffic from lower to higher security level, you would have to explicitly allow icmp traffic to pass through the firewall
as per the nature of work for icmp you would have to allow all the below mentioned in order to be able to ping outside ip address.
try this
access-list out_to_in permit icmp any any unreachable
access-list out_to_in permit icmp any any time-exceeded
access-list out_to_in permit icmp any any echo-reply
access-list in_to_out permit icmp any any unreachable
access-list in_to_out permit icmp any any time-exceeded
access-list in_to_out permit icmp any any echo-reply
also make sure you have acl "out_to_in" and "in_to_out" applied to interfaces
access-group out_to_in in interface outside
access-group in_to_out in interface inside
HTH, please rate it
04-16-2007 09:45 PM
hello,
try this
HTH, please rate it
04-17-2007 03:49 PM
Thanks a lot this fixed it. I had forgotten to apply the access-lists to the interface.
