[Ask please]About Cisco Aironet AIR-AP1121G-A-K9
Apr 16th, 2007
Guys, my company bought a cisco wireless and told me to set it.
It is a Cisco Aironet AIR-AP1121G-A-K9.
my company has one SSID: it is called ADRW. All the wireless's are using the same SSID. And it is hidden so it's not broadcasted..
Set it already all right, but when I tested it, I can't get it to connect. Is it something wrong with my setting? If I change the SSID to something else, for example ADRWX or ADRWXX, it will connect.. Anybody has a clue or something?
Thanks a lot
Suwandy.Ong Thu, 04/19/2007 - 17:36
Thanks for the kind reply, 3iadministrator..
Apparently, I have succeeded to set it up. I changed it to the different SSID, and tested it on my host.
Then, I changed it back to my original SSID which I need, and it's worked now. Maybe it has to be warmed up a little bit
3iadministrator Thu, 04/19/2007 - 19:32
Hi Suwandy,
Not a problem, I have not work on autonomous AP before. maybe i should try that someday on my spare AP.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
