CSA 5.1 - Disabling USB/removable drives
Apr 16th, 2007
As a part of org policy, I want to disable access to any files on USB drive/ any removable drive. Can anyone suggest if it is possible to disable the USB drive/removable drives on CSA ?
I beleive we can only select the file type to block by @removable\*.doc etc.
Pls suggest. Thanks in Advance.
tsteger1 Tue, 04/17/2007 - 09:31
Yes, it is possible using the @removable variable like this:
There is a sensitive data rule in 5.2 you can look at.
nmmailbox Tue, 04/17/2007 - 20:45
Hi, Thx for replying. by 5.2 you mean ver CSA 5.2. The requirement is to stop preventing access to any removable drive and not certain file types only.
Well I have got it done after some brain storming. Thanks any way
tsteger1 Wed, 04/18/2007 - 10:34
Yes, I was referring to CSA version 5.2.
and to block any file you'd use @removable:\**\*.* is all.
Be careful because this file set is used by all the rules in that module (unless you created a separate one).
Hope this helps...
