Hot Standby/Load Balancing for Internet using HSRP
Apr 16th, 2007
  • Silver, 250 points or more
juz got an idea, having 2 different routerz, each routerz pointing to 2 different ISP's & configured HSRP on to it, so will it work fine i mean load balance & hot standby, even if 1 router failz, still the otherz routerz routez the internet packetz?
Router-A
interface serial 0/1
description Connected to ISP-1
ip address x.x.x.x 255.255.255.252
interface ethernet 0/1
no ip address
interface ethernet 0/1.1
encapsulation dot1q 1
standby 2 ip 192.168.1.254
standby 2 preempt
standby 2 priority 109
standby 2 timers 5 15
ip route 0.0.0.0 0.0.0.0 serial 0/1
Router-B
description Connected to ISP-2
no ip address
ip address 192.168.1.2 255.255.255.0
standby 2 preempt
standby 2 priority 108
ofcourse all the workstationz will be having their gateway IP address 192.168.1.254 which is the virtual gateway IP address.
Anand Narayana Mon, 04/16/2007 - 23:33
thankz prem,
but if i want to achieve the load balancing, the only possibility is through PBR isn't?
regarding NAT ofcourse i require that, which i forgot to type that.
nsirin Mon, 04/16/2007 - 23:46
hi it's impossible. When you connect two diffrent ISP , it means you connect two diffrent AS. Each ISP has own real ip blocks and if you want to connect internet from ISP-1 you have to use one of ISP-1 registered ip address. In this scenerio you use one local ip block (it is private block but you can't use it on internet even if you use NAT your lan must be in same subnet).
Anand Narayana Mon, 04/16/2007 - 23:50
Hi NSIRIN,
it is possible as this workz according to the priority, bcoz not 2 routerz r going 2 route the packetz at a time. only when you say a static NAT ofcourse it might be a probz. but not for redundancy.
but my question is, i wanted load balancing where the internet should be used with both the ISP's.
spremkumar Tue, 04/17/2007 - 00:23
  • Red, 2250 points or more
hi
I didnt look at the word 2 different isp as mentioned in your first post yes its possible to have 2 different overload statements riding with 2 different default gateways in your router but you can have outgoing load distributed on both the links but the incoming traffic may not be that evenly distributed in nature.
Because of the same you may experience performance degradation too which we have tested in few cases..
regds
Anand Narayana Tue, 04/17/2007 - 00:27
thankz prem once again,
can you juz post a sample configuration, so that i can under clearly.
