multiple wan links on 1 router 1 link fail other link will auto fail
Apr 17th, 2007
I need to have a setup where we have 2 router 2811 with on each router 3x 2meg ccts, we need ot have a situation where if 1 of the 2meg on on router fail the others will be blocked and traffic will fail-over to redundent router, is this possible?
albert.remo Tue, 04/17/2007 - 00:42
What kind of link are you going to use? Are you going to use IMA? If yes, there is a feature for IMA where you set the minimum active links to 3 so when one link fails, the entire IMA bundle will fail. I don't know if multi-link ppp has the same feature.
mijkel71 Tue, 04/17/2007 - 00:48
we are using ppp links, and we have a situation where 2 link are not able to bear the traffic, and we are not able to load-balance on higher level and therefor we need to have it in this mode for the time being
