FAX with CCM and ATA issue
Apr 17th, 2007
Dear Friends
I have a Cisco CallManger 4.2 with 2800 series gateway and ATA's.
E1 is connected with the gateway.Now when i try to send faxes from my fax machine through the ATA some times the fax reaches the destination
correctly and sometimes not .Same is recieving some times it works and sometimes it does not .
I have not applied any special configuration on E1 for FAX calls .Normal config whcih is
dial-peer voice 100 voip
description Forward Inbound Calls to CM (Subsriber)
preference 1
destination-pattern 8...
voice-class codec 1
voice-class h323 1
session target ipv4:10.7.0.13
dtmf-relay h245-alphanumeric
no vad
Do i need to configure anything on the gateway or ccm or ATA to correct this issue?
Please advise.
regards
Nouman Khan
Aaron Harrison Tue, 05/01/2007 - 01:42
  • Community Spotlight Award,
    Member's Choice, May 2015
First of I'd check your E1 clocking - if this is out then you will get issues like this.
Do a sh controllers e1, check for slips.
If you have them, set your clocking up like so:
network-clock-participate wic 0
network-clock-select 1 e1 0/0/0
Obviously use numbers applicable to your install.
Aaron
Please rate helpful posts...
