IPMA - A couple of questions??
Apr 17th, 2007
The IPMA setup comprises of 5 managers and 5 assistants. When the assistants log in they select the manager and then they select themselves as the default assistant.
I suspect that the list of available assistants is downloaded from the IPMA server when the assistant logs in. Is this info then cached on the PC?
If any changes are made to the assistants/managers setup, do they need to log out and back in to see the changes?
If the data is not cached on the PC, does anyone know how often the data is refreshed from the IPMA server to the client?
Best Regards
