AAA/Radius failures
Apr 17th, 2007
Have a couple of switches setup for AAA/Radius (Microsoft IAS running Radius). All authentication fails when I configure it with a radius key (matching on switch and server).
When I remove the key, I still cant authenticate with my domain credentials, and can only authenticate using the local admin password configured on the switch on a few occasions.
To get back into the switch I have to stop the IAS service on the Microsoft Radius server, log into the switch with the local admin password, before restarting the IAS service.
How can I make AAA/Radius work effectively.
Richard Burts Tue, 04/17/2007 - 04:59
There are several things that you might do:
- reconfigure a switch and reconfigure the Radius server for that switch to eliminate the possibility of configuration mismatch. I would be sure to key in clear text keys rather than cut and paste some encrypted value which you assume will be the same on both ends.
- look on the server to see if there are any log entries that indicate that it saw authentication requests and why they failed.
- run debugs on the switches to see what they are reporting.
marksenteza Tue, 04/17/2007 - 08:19
I switch wasnt giving a clear reason in the event log apart from saying that there was an authentication failure. After reconfiguring the switches over and still getting failures I stopped the IAS service for about 5 mins, which is a rather long time, but after restarting the IAS service the switches responded, so it was more of a Microsoft IAS end of a problem
Richard Burts Tue, 04/17/2007 - 09:51
That is an interesting resolution to the problem and one that I would probably have been slow to think of. I will file this away for future reference.
