one way voice communication problem
Apr 17th, 2007
We are trying to configure a sip gateway with the below configuration. The router is installed with 4 fxo ports which i am connecting to a pstn line with the config as below.
dial-peer voice 10 pots
destination pattern 9t
port 0/0/0
forward digits all
When i dial any outside number through sip soft phone ,I am facing one way voice issue.
There is no sip servers as such in the network.
Aaron Harrison Tue, 04/17/2007 - 13:26
  • Community Spotlight Award,
    Member's Choice, May 2015
Check you have 'IP routing' enabled globally.
Aaron
Please rate helpful posts...
ngss Thu, 04/19/2007 - 00:04
When you say there is not sip servers in the network, then how do you intiate the call?
Which sip softphone are you using?
At you sip phone, what do you configure for sip proxy?
I had done test before, basically you need a dial-peer voip using sipv2 point to your sip softphone
SS
