How to check interface usage under catos?
Apr 17th, 2007
I would like to know how to check the current interface usage on 6509 running CATOS? The interfaces are configured under a VLAN or as trunk. Could you please let me know which command is appropriate in order to check the current interface usage?
show mac x/x just show you the total packet received from the last clear. interface
Overall Rating: 5 (1 ratings)
s-sheffield Tue, 04/17/2007 - 05:07
under CATOS I usually use,
show port counters
show port mac
hope this helps
Stu
Anand Narayana Tue, 04/17/2007 - 05:20
  • Silver, 250 points or more
Hi Amin,
you can also type "show port " to know other detailz.
m.sir Tue, 04/17/2007 - 05:15
  • Gold, 750 points or more
try command
show port mac utilization x/x
you get 5 minutes input/output port rates
M.
hope that helps rate if it does
