Cisco PIX Strange VPN Issue
Apr 17th, 2007
One of my Clients have a couple of Site to Site Tunnels and now they would like to setup a VPN Client as well. I noticed on the Config that the Client is setup however using RADIUS authentication which to my knowledge is being used. I take out the line:
crypto map outside_map client authentication RADIUS
Some of the Tunnels go down!!
What would cause this to happen even if I issue the correct commands to initate the tunnels. I have never seen this happen before can anyone shed some light on this issue.
srue Fri, 04/20/2007 - 05:47
what version of OS? you might have to specifically exempt the tunnel vpns from x-auth.
