ASA 5540 Failover and VPN Cluster
Apr 17th, 2007
Hi Everyone
Is it possible to configure the ASA 5540, using LAN based Failover, to load-balance IPSEC LAN to LAN VPN's ?
I have the feeling that this cannot work, because i believe the active Firewall always will overwrite the Secondary Firewall "load-balancing" priority.
Does anyone having experience with VPN load-balancing?
Is this supporting:
- only Cisco VPN Clients?
- also Cisco EZ VPN clients (including routers + + +)?
- and Standard IPSEC connections (including LAN 2 LAN) ?
For any hints and inputs i would be grateful.
Thanx everyone
Jarle
ftikphillips Tue, 04/24/2007 - 07:12
I have two 5520's that I am using for the sole purpose of SSL VPN load balancing. The documentation wasn't clear on things like how to apply SSL certs but is working now and you can use it for load balancing SSL VPN which also provides fail over.
