Use client VPN tunnel to traverse LAN-to-LAN tunnel
Answered Question
Apr 17th, 2007
I've been troubleshooting a problem and can't get over a hurdle. The ASA is running ASA running 7.2(1)24 code. I'm trying to use a client VPN tunnel to connect to the ASA. The ASA already has a LAN-to-LAN tunnel set up and functioning, and I need the client VPN to access the remote site over the LAN-to-LAN tunnel.
The internal IP address of the local side is 192.168.0.0/24 and the IP of the remote LAN-to-LAN tunnel is 172.20.1.0/24. The clients are handed out 192.168.200.0/24 IPs. I've attached the relevant configuration for the ASA.
When the client VPNs into the network, I can access the resources on the ASA's internal network. Users on the ASA's internal network can access resources across the LAN-to-LAN tunnel. Client VPNs cannot access resources over the LAN-to-LAN tunnel. For the latter, there are no hits on the C-TEST access list.
Thank you for your assistance.
Correct Answer by acomiskey about 9 years 9 months ago
Overall Rating: 5 (1 ratings)
baskervi Tue, 04/17/2007 - 12:21
This solved the problem. By the way, where do you go to mark this as the solution?
acomiskey Tue, 04/17/2007 - 12:23
It's already marked, I guess you figured it out. Glad it helped.
