Ciscoworks LMS 2.6 - syslog.log almost 100 GB
Answered Question
Apr 17th, 2007
We're running LMS 2.6 (CS 3.0.5, RME 4.0.5, CM 4.0.6) on Windows and our syslog.log is now around 98GB. The disk has about 10GB free remaining. I attempted to run logrot.pl set to 0 archives, hoping it would blow away the huge file and create a smaller one for us. Instead, I got this error message: "WARNING: Failed to get a successful value back from D:\PROGRA~1\CSCOpx\bin\logrot_stat.exe, using Perl stat instead (note: this will fail for files > 4GB)". I've heard erasing the syslog.log file causes more problems; what can I do to eliminate this monster and start afresh with a new syslog.log?
Correct Answer by Joe Clarke about 10 years 1 month ago
Okay, I think I see the bug, but I cannot compile a fix for you at the moment. Just run logrot_trunc as I described earlier, and that should clear out your logfile.
From there on out, I recommend scheduling regular logrots to keep the file size under control.
Overall Rating: 5 (1 ratings)
Joe Clarke Tue, 04/17/2007 - 07:25
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
I'd like to fix the logrot_stat bug. What does:
NMSROOT\bin\logrot_stat.exe NMSROOT\log\syslog.log
Report? If this becomes more of an emergency, you can run NMSROOT\bin\logrot_trunc.exe NMSROOT\log\syslog.log to truncate the file without shutting down dmgtd. However, I'd like to find out why the stat helper is not able to ge tthe size of this file.
bread Tue, 04/17/2007 - 07:53
Running the logrot_stat executable gave me the response "7245877142". I don't know what this signifies; actual file size is 106030149137. Thanks for your help and super fast response.
Correct Answer
Joe Clarke Tue, 04/17/2007 - 08:00
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
bread Tue, 04/17/2007 - 08:18
Slick! That took care of the oversized file problem in about 15 secs. Thanks for the help. And yes, we'll be running logrot.pl on a regular basis from now on. Thanks again!
