Lan based failover session key encryption for PIX
Apr 17th, 2007
My suggestion for session key encryption for a lan based failover connection for the PIX is as follows:
A) Physically connect PIX interfaces to a workgroup amd or enterprise Catalyst 6509 switch, IOS 12.2(18) SXF and higher.
B) Assign static IP addresses within the range of the primary and failover PIX units.
C) Configure session key encryption on the workgroup switch and only allow TCP packet segments via IP protocol number 105/SCPS. Then deny all other TCP/IP segments.
The configurations should be as follows:
Company A 6509#show run
version 12.3
hostname Company A 6509
boot-start-marker
boot-end-marker
enable password cisco
no aaa new-model
ip subnet-zero
no crypto isakmp enable
crypto ipsec transform-set encrypt-aes esp-aes esp-sha-hmac
crypto map pix failover 8 ipsec-manual
set peer 11.11.11.6
set session-key inbound esp 1001 cipher 1234abcd1234abcd authenticator 20
set session-key outbound esp 1000 cipher abcd1234abcd1234 authenticator 20
set transform-set encrypt-aes
match address 101
interface gi2/2
speed 100
duplex full
Description PIX failover interface Lan-Based access list applied to protocol 105 for SCPS
ip address 11.11.11.5 255.255.255.252
ip http server
no ip http secure-server
ip classless
ip route 0.0.0.0 0.0.0.0 11.11.11.12
access-list 101 permit ip host 11.11.11.5 host 11.11.11.6 eq 105
access-list 101 permit ip host 11.11.11.6 host 11.11.11.5 eq 105
access-list 101 deny ip any any
access-list 101 permit ip any any
line con 0
no login
line aux 0
no login
line vty 0 15
exec-timeout 300
transport input ssh
login
If possible, try this on a home lab, then verify the results.
thomas.chen Mon, 04/23/2007 - 06:23
The failover configuration requires two identical security appliances connected to each other through a dedicated failover link and, optionally, a stateful failover link. The health of the active interfaces and units is monitored to determine if specific failover conditions are met. If those conditions are met, failover occurs.
The security appliance supports two failover configurations, Active/Active Failover and Active/Standby Failover. Each failover configuration has its own method to determine and perform failover. With Active/Active Failover, both units can pass network traffic. This lets you configure load balancing on your network. Active/Active Failover is only available on units that run in multiple context mode. With Active/Standby Failover, only one unit passes traffic while the other unit waits in a standby state. Active/Standby Failover is available on units that run in either single or multiple context mode. Both failover configurations support stateful or stateless (regular) failover.
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00807dac5f.shtml
