Cisco 2621 Can't connect 2 LANs
I have a Cisco 2621, and Can't connect 2 LANs. I have 2 Fast Ethernet interfaces, but need some help with the code to get the 2 to see each other, and share resources.
I have 2 LANs - 10.38.77.0 and 192.168.0.0. I can ping both LANs from the router, but, from each side, can only ping that LAN.
Any help would be greatly appreciated!!
Harold Ritter Tue, 04/17/2007 - 07:52
  • Cisco Employee,
Make sure that the workstations are configured with a default gateway, which is the router interface address in the respective subnet.
Hope this helps,
Jon Marshall Tue, 04/17/2007 - 07:55
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Hi Larry
Can you make sure ip routing is enabled on the 2621 router. It should be by default so unless there is a statement
"no ip routing" in the config you should be okay.
Could you send a copy of the 2621 config ?.
Have you set the PC's default gateway to be the relevant router interface ?
Jon
Routing is enabled.
I have the router I/Fs set to 10.38.77.35 and 192.168.0.35
I have 2 test machines with respective addresses of 10.38.77.177 and 192.168.0.6
The config is below:
Router#sho runist
Building configuration...ntry
Current configuration : 714 bytes alias Crea
version 12.2
service timestamps debug uptime
alps
service timestamps log uptimeol
!d
call rsvp-syncp parameters
interface FastEthernet0/0
autonomous-sys
ip address 10.38.77.35 255.255.255.0to which we belong
duplex auto
speed auto
interface FastEthernet0/1ger Configure Backhaul
ip address 192.168.0.35 255.255.255.0
speed auto
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.0.2
ip route 10.38.77.0 255.255.255.0 10.38.77.177
ip route 10.38.77.0 255.255.255.0 192.168.0.0
ip route 192.168.0.0 255.255.255.0 192.168.0.6
ip route 192.168.0.0 255.255.255.0 10.38.77.0
no ip http server
ip pim bidir-enable
dial-peer cor custom
line con 0
line aux 0
line vty 0 4
end
bmbreer Tue, 04/17/2007 - 10:10
Get rid of the static routes you have configured(see above). Make sure the hosts on the 192.168.0.0/24 network are using 192.168.0.35 as their default gateway.
Make sure the hosts on the 10.38.77.0/24 network are using 10.38.77.35 as their default gateway.
Well, I thought it worked on the test machines, but didn't test internet on Both - only one of them. So, when I put them on-site, the only way they talked to each other was to set each LAN gateway as the other's firewall.
So am I correct in thinking that I need to (as stated in an earlier reply) set each LAN's workstations' gateway as the corresponding FA address? And then add routes from each of those to their respective firewalls as below?
ip route 10.38.77.35 255.255.255.0 10.38.77.130
ip route 192.168.0.35 255.255.255.0 192.168.0.4
