WCS + linux + http access
Apr 17th, 2007
Hi to all!
I?ve installed WCS v. under Red Hat enterprise v4.
Everything works fine but i got just a simple question: i disabled http accessing and and enabled https. Now i?d like to enable http but i don?t find where to change that feature, And also i can?t find where i can change the acessing ports (80 and 443). Through WCS GUI don?t find and i was was wondering i it could be possible to do editing any config file. Is this possible?
Thanks in advance to all.
vkapoor5 Mon, 04/23/2007 - 06:25
WCS Software includes a web server that is configured to use the default http and https ports. If you have another web server installed on the same system that use the same ports the WCS will not start. Please disable or Uninstall the other Web server
before starting the WCS.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
