IPCC Express + Automating Cisco Agent Desktop Installation
Apr 17th, 2007
Has anyone figured out how to automate the
Cisco Agent Desktop or Supervisor Desktop
installation using software distribution
mechanisms like MS AD GPOs?
I realise that using appuser/appadmin plug-in
method is straightforward, but a client wants
to push this out in a controlled manner.
It makes sense that the CAD software can be
silently installed using an answer file and
software distribution mechanisms, so I have
to ask.
Thanks.
emikelso Thu, 05/10/2007 - 19:06
Did you ever get a response to this? I'm trying to do the same thing.
Thanks.
davidwomer Fri, 05/11/2007 - 15:58
Once you have the system installed you can grab the executable boostrap programs and push them out to the desktop. From that point on you will need to automate the setup with either macros or an answer file.
