Cisco 7206 T1 IMA card
Apr 17th, 2007
I recently came into posession of a Cisco 7200 Series router, which I will be using to upgrade the network of a local non-profit. It came with various cards installed, including a T1 IMA 8-port card (model PA-A3-8T1IMA). Whenever I power on the router it says:
%OIR-3-SEATED: Insert/removal failed (slot x), check card seating.
It does this no matter what slot the card is plugged into. Does this mean that the card is toast? Or do I perhaps need to update something for it to work properly.
spremkumar Wed, 04/18/2007 - 21:01
  • Red, 2250 points or more
have you tried reseating the card onto the slot again which is mentioned in this error message ?
or else switch the box off and make sure all the modules are installed properly on the respective slots to avoid any future failures or error messages..
regds
gideon1331 Thu, 04/19/2007 - 12:15
I have tried putting the card into any one of the six slots, both by itself and with other cards installed to no avail.
