04-17-2007 09:41 AM - edited 03-09-2019 05:49 PM
Per Cisco doc, I need 3 GB or more on /u01 to upgrade from 4.2.2 to 4.2.3. diskusage says I have 2.7 GB. Any ideas on cleaning up that partition? Does turning on archiving affect /u01? Thanks, Brent
04-18-2007 02:25 AM
hi,
i've noticed the same "problem" before upgrading to 4.2.3. (diskusage says 2.7GB too;-), but the upgrade although works fine (after several tries ;-).
the thing with 2.7GB occured after a failed upgrade to version 4.2.3. before this upgrade, i had much more than 3GB free on this partition.
Archiving (to a nfs server) had been turned on long before i run the update (an is still running), but i've still only 2.7GB free on /u01 (currently running 4.2.5)
The Documentation says following to your (my) problem:
"A nightly process runs to clean up any files that accumulate on this partition. If you have less than 3 GB, there is an issue with your appliance that you must resolve prior to upgrading. "
It sounds a little bit mystic and unfortunately it doesn't give a hint how to "reslove" that.
maybe some cisco technician can explain this behavior......
regards,
bernhard
04-18-2007 06:42 AM
Yeah, I'm hoping the "several tries" part works for me. I've already tried and failed twice. Thanks.
08-01-2008 01:44 AM
same problem here, do I really have to wait until tomorrow to continue upgrade process because of not enough disk space and inability to clean it manually?
*sigh*
08-01-2008 08:38 AM
Confirm that you read the 4.2.3 part of this doc:
from this site
http://www.cisco.com/en/US/products/ps6241/prod_installation_guides_list.html
cli method is the best way to upgrade (and pointing to the DVD with the upgrade files).
