Multiple VTPs over a single fiber link
Apr 17th, 2007
Is there a way to transport multple VTP domains over a single fiber link? We have 2 seperate locations we want to connect, which have muliple VTP domains.
Thanks in advance.
mahmoodmkl Tue, 04/17/2007 - 10:37
  • Gold, 750 points or more
This is not possible,but if u want to connect this two locations then what u can do is create a vlan on each location with same vlan ID and configure the ports which will be used for connecting in the vlan.
Mahmood
Trony Thu, 04/26/2007 - 08:42
Will MPLS work as a alternative solution?
glynncounty Wed, 12/05/2007 - 17:00
You can connect multiple VTP Domains. Just as was said above, as long as VTP Domain A and VTP Domain B both have a shared VLAN say Vlan 16 you simply add a routing statement and you have inter VTP Domain communication.
