AP1310 IOS Problem
Apr 17th, 2007
I currently have a CIsco 1310 which seems to have died. For some reason it wont boot. No bootable files found. When trying to TFTP an IOS to it I keep getting Invalid Argument. Can anyone please help me with what I might be doing wrong. Thanks in advance.
b.julin Wed, 04/18/2007 - 07:00
when using the ROM loader, you always have to prepend the "drive" (filesystem), it does not default to flash:
Also you have to set environment variables to give it an IP and gateway to reach the TFTP server.
jmilay Wed, 04/18/2007 - 09:21
So would this statement be correct?
tar -xtract tftp://192.168.1.7/tftp/c130-rcvk9w8-tar.123-11.JX1 flash:
After tftp_init I enter the above command and it returns with invalid argument.
I am directly connected to it with a crossover cable, configured the 1310 with:
IP_ADDR 192.168.1.5
NETMASK 255.255.255.0
DEFAULT_ROUTER 192.168.1.1
Laptop with :
192.168.1.7
255.255.255.0
192.168.1.1
Using Pumpkin as tftp server:
it hits the pumpkin server fine but as soon as I grant access to the file I get the Invalid Argument error.
b.julin Wed, 04/18/2007 - 09:27
That's the right statement, IIRC.
But the same file I have ends with a .tar. Are you sure that's not a directory where you've already unpacked the tar on the tftp server, and not the tar file you think it is?
Also check that your TFTP server actually requires the absolute "/tftp/" path and not just the filename.
(note you are missing a "1" if you cut and pasted that.)
jmilay Wed, 04/18/2007 - 09:42
No I typed it in (*reference the missing "1" in 1310) and I also forgot to type the ".tar" part (Actually tried it with and without it). I've typed it out in notepad and copy/pasted in the console. Did not do that for this post. Also I tried it with and without the "tftp" directory.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
