CSA 5.1 and MS Office Updates
Apr 17th, 2007
My organization is running into problems with the office 12 update feature failing due to CSA. Would the process for allowing this activity be similar to what I've read for Windows Update?
Overall Rating: 4 (1 ratings)
tsteger1 Tue, 04/17/2007 - 13:28
It would be similar but not the same. Have you tried the wizard to create exceptions yet?
Making exceptions for Office and Windows Update is possible but can open holes.
It's much easier to create exceptions for MS SUS/WSUS or some internal patch management tool. Is that an option at all?
Then you could manage your CSA exceptions and updates at the same time in the same way.
Tom
