1310 LWAPP, external Antenna
Apr 17th, 2007
Hi guys, I just converted an 1310 AP to LWAPP. When autonomous, it used external antenas, but now under the controller configuration I can't select "external" for the type of antenna. I tried GUI and CLI. I know theres a known bug for the 1500 and 1030 AP regarding this kind of behavior, bout i coulndt find anything about the 1300 Model.
Any suggestions or info?
Thanks in advance!
fmeetz Mon, 04/23/2007 - 08:58
  • Bronze, 100 points or more
If you set the AP to brigdemode first you wont be able to choose external antenna on the 802.11a radio later (the field where you choose antenna mode will be Omni and you can and change it), but if you set the antenna to external before changing the AP mode to bridge it works.
omarmontes Mon, 04/23/2007 - 09:06
Hi and thanks for the reply.
The 1300 was always configured to act as AP, not as bridge, and that remains the same now workings as LWAPP
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
