ids-4fe-int 33vs66
marcabal Tue, 04/17/2007 - 14:04
  • Cisco Employee,
The IDS-4FE-INT is the official part number of the card, and only this card is supported in an IDS-4215 chassis.
As you noted, the Pix had 2 types of 4FE cards that it supported.
One of these is the same card as the IDS-4FE-INT part number (the PIX-4FE-66 I beleive). And that Pix part number which is the same card as the IDS-4FE-INT, can be used in the IDS-4215.
So I believe that IDS-4FE-INT and PIX-4FE-66 are 2 Cisco Part Numbers for the same 4FE NIC card. The Cisco part numbers differ because of which product it was sold for.
The other Pix 4FE part number (PIX-4FE I think), however, was an older rev PCI card and can NOT be used in the IDS-4215.
The IDS/IPS software will Not recognize that older card and that older card has never been sold as an IDS/IPS part number.
Hope this answers your question.
garylash8016 Tue, 04/17/2007 - 15:05
thank you for your input. i was experimenting with the pix-4fe in the ids4215 and found that it did indeed recognize it. was able to ping out each port also. thats why i was wondering about the pix-4fe. because my boss told me the same thing. maybe we are misidentifing the card?
stevehorsleyNXG Wed, 11/14/2007 - 13:43
If it works in the IDS, it must be the 66 version, as the 33 version will not be recognised.
