04-17-2007 01:53 PM - edited 02-21-2020 01:29 AM
I am having BIG problem! We are testing hub & spoke configuration
CISCO876>>ALCATEL DSL SYSTEM<<CISCO876
HUB SPOKE
2 vlans 2 vlans
One VLan should be used for VIDEO traffic and another for VPN! Current
configuration is behaving very unstable, links are going down every 5
min and connection between HUB and SPOKE is not WROKING unfortunaly?! :
Can some give me clue what to do next?
Here is the configs:
Building configuration...
Current configuration : 1592 bytes
version 12.4
no service pad
hostname BUNDLE
boot-start-marker
boot-end-marker
enable password pass
no aaa new-model
resource policy
ip cef
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface ATM0
no ip address
atm ilmi-keepalive 5 retry 5
dsl operating-mode auto
hold-queue 224 in
interface ATM0.1 point-to-point
description Subinterface for ViSS
ip address 192.168.1.2 255.255.255.252
ip virtual-reassembly
no snmp trap link-status
atm route-bridged ip
pvc 1/32
interface ATM0.2 point-to-point
description Subinterface for LSVPN
ip address 192.168.2.2 255.255.255.252
pvc 0/35
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
description ViSS port
switchport access vlan 10
interface FastEthernet3
description LSVPN port
switchport access vlan 20
interface Vlan1
no ip address
interface Vlan10
description LAN for ViSS
ip address 10.10.1.1 255.255.255.0
interface Vlan20
description LAN for LSVPN
ip address 10.10.2.1 255.255.255.0
ip route 10.10.1.0 255.255.255.0 ATM0.1
ip route 10.10.2.0 255.255.255.0 ATM0.2
no ip http server
no ip http secure-server
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
password pass
login
scheduler max-task-time 5000
webvpn context Default_context
ssl authenticate verify all
no inservice
end
HUB CONF :
version 12.4
no service pad
hostname BUNDLE
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip cef
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface ATM0
no ip address
hold-queue 224 in
ip address 192.168.3.2 255.255.255.252
pvc 1/32
ip address 192.168.4.2 255.255.255.252
pvc 0/35
interface Vlan1
no ip address
interface Vlan10
ip address 10.10.3.1 255.255.255.0
interface Vlan20
ip address 10.10.4.1 255.255.255.0
ip route 10.10.3.0 255.255.255.0 ATM0.1
ip route 10.10.4.0 255.255.255.0 ATM0.2
no ip http server
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
password pass
login
no inservice
end
Waiting for replys!
04-17-2007 08:21 PM
Are you seeing error messages getting logged when the link goes down ?
regds
04-17-2007 10:27 PM
I am not getting error. I've debugged atm events,ilmi I've not seen any errors. Subinterfaces atm0.1 and atm0.2 are UP UP but one of pings(LSVPN) hub>spoke to the other side is request time out.On the other side spoke>hub same ping(LSVPN) is giving request time out.
