ariela Tue, 04/17/2007 - 16:05
please try this:
username test nopassword autocommand telnet 10.30.4.5 /source vlan2
Let me know
Andrea
Paolo Bevilacqua Wed, 04/18/2007 - 09:21
12.4XJ as of today is only 12.4(11)XJ1 or XJ2.
Also tried with 12.4(11)T, same result.
Does it work for you ?
ariela Wed, 04/18/2007 - 09:59
well,
I've you already tried with:
Andrea
Paolo Bevilacqua Wed, 04/18/2007 - 10:08
Yes as it told you before ...
Without autocommand is command not valid!
sundar.palaniappan Wed, 04/18/2007 - 10:17
Paolo,
I quickly tested your setup in my lab and it works fine. I don't know if there's a 'additional blank space' or 'space missing' in your autocommand syntax. Try removing the config and reentering it.
username test autocommand telnet 172.30.1.11 /source loopback123
R2#172.30.1.12
Trying 172.30.1.12 ... Open
User Access Verification
Username: test
Trying 172.30.1.11 ... Open
Password required, but none set
[Connection to 172.30.1.11 closed by foreign host]
[Connection to 172.30.1.12 closed by foreign host]
Sundar
