04-17-2007 02:59 PM - edited 03-13-2019 04:04 PM
Our receptionist console PC based display jumps around the screen when any calls are made to the reception/main number. Functionality seems intact, but the new attention grabbing feature is some annoying and I would like to disable this.
Solved! Go to Solution.
04-18-2007 06:16 AM
There is a small button that you have to press to disable this behaviour, it is located at the bottom of the AC window. I'm attaching a screenshot of my lab's AC showing the button that I'm talking about.
//Jorge
04-17-2007 06:09 PM
There is a option in the attendant console to prevent the screen from jumping to the front of the screen.
Please rate my post!
James
04-18-2007 06:16 AM
04-18-2007 08:00 AM
Hi Wayne,
To add a note to Jorge's good info, you can also use this method to enable/disable "Pop to Top"
Note: To toggle the pop-to-top feature on and off, press Alt + P.
From this doc;
Hope this helps!
Rob
