Configuration of Catalyst 2950 with WLC 2106
Apr 17th, 2007
I am current setting up a simple wireless network consist of 2 Aironet 1130 AP,1 WLC 2106 and 1 Catalyst 2950 24 ports.I configured the AP Manager and Management interfaces both on the VLAN 30. at the same time I configured Catalyst 2950 Fa0/6 to be the trunk port connected to the Management port of WLC 2106.which is port 1.and I configure my Fa0/4 as access port for VLAN 30.which i connected it to my laptop.I am able to continously ping to the WLC 2106 management interface IP address from my laptop without fail.the problem appeared when i plug in my 1130 AP to the switch on another port which is configured as VLAN 30. I also connect the AP manager interface port to the catalyst port of VLAN 30. how should i go about it? thanks.
note: the AP should plug to the switch instead to the WLC directly.
any expert can clear my doubt? T.I.A
ankbhasi Wed, 04/18/2007 - 00:39
Hi Friend,
I did not understood your problem? Can you explain again when you said "the problem appeared when i plug in my 1130 AP to the switch on another port which is configured as VLAN 30. I also connect the AP manager interface port to the catalyst port of VLAN 30. how should i go about it?"
You have to map your management as well as ap-manager interface both to port 1 on controller and when you connect your AP on 2950 switch on vlan 30 it will join your controller.
Ankur
3iadministrator Wed, 04/18/2007 - 02:04
Hi Ankur,
Yeah, you are right on this.I discovered the same thing as well. my mistake, as I assigned ap-manager to port 2.where it should be on port 1.mistake #2.there is no requirement for physcial connection between ap-manager interface with the switch.
thank for the reply.
best regards
Jack
