Cisco 3725 and NM-8AM-v2
Apr 17th, 2007
As I try to configure this cisco, i notice that it does not support the command modem and even the first system configuration dialog will generate error after it finish the wizard. the ios version: IOS (tm) 3700 Software (C3725-I-M), Version 12.3(6b), RELEASE SOFTWARE (fc1)
Does it required to update the ios or license to support the modem feature? the purpose is to install it as a RAS.
spremkumar Tue, 04/17/2007 - 19:53
  • Red, 2250 points or more
did u check whether your network module has got detected by the current ios ?
you can verify the same using show version command and find whether your module is getting displayed.
regds
kcdara1980 Tue, 04/17/2007 - 20:02
it has been detected as undefine port type 400 during start up, but in the show version it does not list.
spremkumar Tue, 04/17/2007 - 20:57
Its not only the ios version which is required to be checked out for compatibility you need to check up the feature set too...
regds
kcdara1980 Tue, 04/17/2007 - 21:16
So far I found that my image c3725-i-mz.12.3-6b.bin is IP feature set which does support RADIUS and should support the module nm-8am-v2. Do I need to check something else?
