Led AP1130
Apr 17th, 2007
I connect a LAP1131 to power injector and its led status change to amber? what means this? The AP is registered in the wireless lan controllers but its Operational status is Down. I selected the "power injector states" check box.
Adam Watts Thu, 04/19/2007 - 14:27
not sure if this will help, but assuming the ap's are plugged into a cisco switch you have to turn CDP off on the ports you are using.
i had a similar problem with a group of 1242's i had on older cisco switches. turned cdp off and it worked fine.
Adam Watts Thu, 04/19/2007 - 14:28
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
