security lab CCSP
Apr 17th, 2007
i wish if you can help me to build a CCSP LAB for demo and testing purposes.
Please advice what equipment i should use, and what scenarios best to simulate.
m.sir Tue, 04/17/2007 - 22:28
It depends what exam you want take
there are 5 exams for CCSP
I suggest 2 routers (for VPN, CBAC, Auth-proxy etc..) and one switch (for 802.1x , port security) and also server with ACS installed
For SNPA one PIX running 7.x code and one ASA
For IPS - Cisco IPS 4215 at least with 3 interfaces for inline mode testing and router for blocking testing
For CSVPN - VPN concentrator 3000 series
If you want build one global lab for all exams
I suggest 2-3 routers , ACS, IPS 4215, PIX, ASA, VPN concentrator - this lab is close to CCIE security setup so maybe some CCIE securit rack rental could be helpful
