ips mode
Apr 17th, 2007
hello,
am i right in saying;
1. if ips is in ips mode, then i have to use interface pair?
1. if we have interface pair, does this 2 interfaces has to be in different subnets?
thanks
m.sir Tue, 04/17/2007 - 22:40
  • Gold, 750 points or more
1. Yes you are right you need two interfaces and IPS acts like bridge
2. IPS doesnt route between subnets and is used like transparent bridge - so you can place it between two computers in same network and its transparent for those PC
pc1 ----IPS ----pc2
BUT you can use also VLAN pairs - packets received on one of the paired VLANs are analyzed and then forwarded to the other VLAN in the pair.
Check this link for more details
http://www.cisco.com/en/US/products/hw/vpndevc/ps4077/products_configuration_guide_chapter09186a0080459225.html#wp1033986
M.
cfajardo1_2 Wed, 04/18/2007 - 22:37
so if it is in inline mode and i have a flat network, all conversations should pass thru my IPS.
Do I have to configure anything on my switch on this case. aor whta has to be done to achieve this.
thanks
