E1 PRI down
manumohan200
I am having a 3825 as a Voice Gateway. My PRI to the provider is shown as down in "show controllers e1" output. Also in the show isdn status it is shown as LAYER 1 DEACTIVATED.
I suspected the problem with the provider, but the he claims everything is working fine. He even connected on PRI phone to this PRI line and was able to make calls in & out.
My card is VWIC-MFT-2E1. I am pasting the show version, show running and show controller configuration. Please help to resolve this issue.My IOS version is 12.3(14)T7
CHE-BL1-CR0101-3825#sh run
network-clock-participate wic 1
isdn switch-type primary-net5
voice-card 0
dspfarm
dsp services dspfarm
controller E1 0/1/0
framing NO-CRC4
pri-group timeslots 1-31
description PRI connection to TATA
interface Loopback1
description Monitoring & Logging
ip address 192.168.19.106 255.255.255.255
h323-gateway voip interface
h323-gateway voip bind srcaddr 192.168.19.106
interface GigabitEthernet0/0
description Connect to Core VLAN on CHE-BLD1-CR0101-6509
ip address 192.168.100.9 255.255.255.248
duplex full
speed 1000
media-type rj45
negotiation auto
interface Serial0/1/0:15
no ip address
isdn incoming-voice voice
no cdp enable
control-plane
voice-port 0/1/0:15
voice-port 0/1/1:15
sccp local Loopback1
sccp ccm 10.226.80.12 identifier 2 version 4.1
sccp ccm 10.226.80.11 identifier 1 version 4.1
sccp
sccp ccm group 1
associate ccm 2 priority 2
associate ccm 1 priority 1
associate profile 1 register CHE-CFB-CONF-1
dial-peer voice 2 voip
description Chennai
preference 1
destination-pattern 2...
progress_ind setup enable 3
session target ipv4:10.226.80.11
codec g711ulaw
no vad
dial-peer voice 4 pots
preference 2
destination-pattern .T
direct-inward-dial
dial-peer voice 1 pots
preference 1
direct-inward-dial
port 0/1/1:15
dial-peer voice 3 voip
preference 2
session target ipv4:10.226.80.12
dial-peer voice 5 voip
preference 3
session target ipv4:192.168.19.105
CHE-BL1-CR0101-3825#sh isdn status
Global ISDN Switchtype = primary-net5
ISDN Serial0/1/0:15 interface
dsl 0, interface ISDN Switchtype = primary-net5
Layer 1 Status:
DEACTIVATED
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0x00000000
Number of L2 Discards = 0, L2 Session ID = 1
CHE-BL1-CR0101-3825#sh controllers e1
E1 0/1/0 is down.
Applique type is Channelized E1 - balanced
Description: PRI connection to TATA
No alarms detected.
alarm-trigger is not set
Version info Firmware: 20050620, FPGA: 16, spm_count = 0
Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (142 seconds elapsed):
765563 Line Code Violations, 97982 Path Code Violations
12 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 142 Unavail Secs
Total Data (last 24 hours)
4755637 Line Code Violations, 541985 Path Code Violations,
74 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 86400 Unavail Secs
Manu
6 Replies 6
smothuku
Level 7
Level 7
Hi Manu ,
check how much voltage you are getting in PRI line with multimeter....
Satish
Thanks for the reply. What is the normal voltage for the PRI and BRI ?
Manu
Hi Manu,
Voltage check makes no sense for ISDN. You have likely a cabling problem because you receive no signal. Check again the pinout for your card, if the circuit is balanced / unbalanced.
Note the PRI telephones do no exist, your provider may have used a test device, but not a phone. Call him again to make the correct cable so the circuit can be used.
Layer 1 Status:
DEACTIVATED
Layer 2 Status:
Layer 3 Status:
E1 0/1/0 is down.
No alarms detected.
Hi Manu,
Just see how many Line Code violations and Path Violations are there on the interface / controller card.
I'm sure this is an L-1 issue, I would go ahead and do the following:-
1. Clear the counters and see if the numbers do increase.
2.Check the cabling from the demarc to the Router
2. Check the Ground connectivity on the Router
3. Change the Controller Card and check if the err are still there or not.
pkentsmith
Hi Manu,
I'm sure you've checked this already: -
Are there any alarms on the NTE?
If you have multiple presentations (Ethernet, X21 & Coax), check provider has configured the NTE for the correct one
You should have alarm lights on, try putting a loop on the NTE with a physical cable and seeing if they go out
The above might work
PKS
