qos in layer2
Apr 18th, 2007
hi,
i have some question about qos in layer2.
we have a router on one side which does qos with the dscp value which we are settin in the router based on acl?s.
the router is connected over a ethernet to a switch (no trunk).
how can i achive that the switch does qos based on the dscp values which the router is setting.
Overall Rating: 3.5 (2 ratings)
rabeder Wed, 04/18/2007 - 02:24
hi, thank you.
just one (two) questions regarding this:
if the router sets the dscp value in the ip header, who sets the 3 bits cos value in layer two even this connection is no 802.1q
connection - its a user port in the switch.
- does the switch automaticly sets cos from the layer3 dscp it receives from the router ?
thanks for answer
