Does C4506 support mpls
Answered Question
Apr 18th, 2007
Hi all,
I have an existing Sup I on C4506 and C4507R, and I need to upgrade a network for the upcomming project, which of the sup card can support QOS,POE,MPLS and other routing protocol.
Raj
Correct Answer by eofelt about 9 years 10 months ago
IP Routing Protocols
The following routing protocols are supported on the Catalyst 4500 series switch:
BGP
OSPF
IGRP
IS-IS
OSPF
RIP
VRRP
http://www.cisco.com/en/US/products/hw/switches/ps4324/products_configuration_guide_chapter09186a0080731433.html#wp1031485
With the base IP image, it will only run Eigrp
as a stub. I didn't see anything about MPLS aside from VPN support.
A SupII will support current images and features.
hth
Overall Rating: 5 (2 ratings)
Danilo Dy Wed, 04/18/2007 - 04:38
Hi Raj,
4500 series platform supports QoS, MPLS, PoE, and other routing protocol. This however depends on the supervisor engine, IOS, and inline card.
Check model comparison http://www.cisco.com/en/US/products/hw/switches/ps4324/prod_models_comparison.html
Check data sheet
http://www.cisco.com/en/US/products/hw/switches/ps4324/products_data_sheet0900aecd801792b1.html
I can't comment on Supervisor Engine I
Correct Answer
eofelt Wed, 04/18/2007 - 04:52
BGP
OSPF
IGRP
IS-IS
OSPF
RIP
VRRP
hth
rkcontrol Wed, 04/18/2007 - 21:06
Hi Eofelt,
From the link above it clearify that MPLS is not supported by C4500 series no matter which ever Sup card one uses.
So can conclude that C4506 and 07R will be of no use if I plan to use MPLS in my network.
Thank u very much for ur reply and Link provided.
Raj
eofelt Thu, 04/19/2007 - 08:05
Raj,
Thank YOU for posting a great question!
And thanks to Cisco for well run forum.
There's some awesome knowledge transfer here.
Amit Singh Wed, 04/18/2007 - 08:45
Raj,
Cat4500 deosnot support MPLS at this point of time. It supports QOS,POE and basic/advanced routing protocols.
QOS is supported on all the supervisor engines. Sup2+/Sup2+10-GE/Sup2+TS supervisor engines are L2 sup engines only and supports basic layer 3 routing protocols only i.e Ripv1/v2 and inter-vlan routing only. Supervisor engine 4/5/5-10GE supports all the basic and advanced routing protocols.
POE is supported accross al the chassis, you need POE capable power supplies and POE capable line cards on the chassis.
HTH,Please rate if it does.
-amit singh
rkcontrol Wed, 04/18/2007 - 21:13
Hi Amit,
Thank u very much for ur reply, U both have replied to my question.
U both deserve 5 points. I am confused how do i rate.
Many thanks,
Rajendra Bhatt.
Amit Singh Wed, 04/18/2007 - 21:23
Raj,
Click on "rate this post " on the right hand side of the post that you want to rate. Give the ratings as per your satisfaction :-)
-amit singh
