Translation pattern to convert number to pilot number
Answered Question
Apr 18th, 2007
I would appreciate some help in suitable method of translating a published number for a group XXXXXXX9640 and would like this translated to a ephone-hunt group pilot number (i.e. 5002), can anyone suggest the best method?
Correct Answer by Chris Deren about 10 years 2 months ago
Use either translation rule or num-exp. You did not specify how many digits you are getting from telco. For the following example lets assume it's 4.
voice translatio-rule 1
rule 1 /^9640/ /5002/
voice translation-profile 1
tranlsate called 1
dial-peer voice 1 pots
incoming called number 9640
translation-profile incoming 1
you can also apply the translation profile to voice-port.
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a0080325e8e.shtml
num-exp is slighly easier all you would need to do is:
num-exp 9640 5002
HTH, please rate helpful posts!
Chris
Overall Rating: 5 (4 ratings)
paolo bevilacqua Wed, 04/18/2007 - 03:57
  • Hall of Fame,
    Founding Member
you don't even need to translate, but if you have DID, likely you are translating already.
Eg:
ephone-hunt 1 sequential
pilot 5002 secondary xxxxxx9640
If were translating already on incoming, leaving the DID portion only, that would be:
pilot 5002 secondary 9640.
Hope this helps, please rate post if it does
Correct Answer
Chris Deren Wed, 04/18/2007 - 03:59
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
tranlsate called 1
num-exp 9640 5002
Chris
lfulgenzi Tue, 05/15/2007 - 13:50
  • Silver, 250 points or more
Thanks Chris. This link helped.
I had seen it before and thought to myself, when would I ever need the 'number slice' feature....well, I just found one!
Thanks again.
