EMI
Dears Netpro!
1)based on the following output,can i Upgrade the Software to EMI Image;if so what IOS Support this Switch
Switch#sh ver
IOS (tm) C3500XL Software (C3500XL-C3H2S-M), Version 12.0(5)XU, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2000 by cisco Systems, Inc.
Compiled Mon 03-Apr-00 17:31 by swati
Image text-base: 0x00003000, data-base: 0x00301398
ROM: Bootstrap program is C3500XL boot loader
Switch uptime is 1 hour, 39 minutes
System image file is "flash:c3500XL-c3h2s-mz-120.5-XU.bin"
cisco WS-C3548-XL (PowerPC403) processor (revision 0x01) with 16384K/1024K bytes of memory.
Processor board ID 0x17, with hardware revision 0x00
Last reset from power-on
Processor is running Enterprise Edition Software
Cluster command switch capable
Cluster member switch capable
48 FastEthernet/IEEE 802.3 interface(s)
2 Gigabit Ethernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:02:B9:B8:C7:40
Motherboard assembly number: 73-3903-04
Power supply part number: 34-0971-01
Motherboard serial number: FAA04299PML
Power supply serial number: PAC042801MZ
Model revision number: A0
Motherboard revision number: B0
Model number: WS-C3548-XL-EN
System serial number: FAA0428F1HV
Configuration register is 0xF
Switch#sh flash
Directory of flash:/
2 -rwx 1644045 Apr 04 2000 00:53:30 c3500XL-c3h2s-mz-120.5-XU.bin
3 -rwx 94674 Apr 04 2000 00:53:30 c3500XL-diag-mz-120.5-XU
4 drwx 6784 Apr 04 2000 00:53:31 html
111 -rwx 272 Jan 01 1970 00:00:12 env_vars
112 -rwx 5236 Mar 01 1993 00:59:24 vlan.dat
113 -rwx 2161 Mar 01 1993 01:37:41 config.text
114 -rwx 4776 Mar 03 1993 03:06:31 config.old
3612672 bytes total (835072 bytes free)
Switch#
2) what is this:
regards
Ali
Overall Rating: 5 (1 ratings)
Danilo Dy Wed, 04/18/2007 - 04:00
  • Blue, 1500 points or more
Hi Ali,
WS-C3548-XL-EN which already reached EOL doesn't support EMI. It's replacement model which is WS-C3550-48-EMI does, but this model already reached EOS.
