AAA auth with ip http server not working
Apr 18th, 2007
Hi all,
I am unable to get ip http server to authenticate against tacacs. attached is the debug output when logging in with the user "mark".
Router config:
aaa new-model
aaa authentication login default group tacacs+ local enable
aaa authentication login ALREADY-IN none
aaa authentication login web group tacacs+ local enable
aaa authorization exec web group tacacs+ local if-authenticated
aaa session-id common
ip http server
ip http authentication aaa login-authentication web
ip http authentication aaa exec-authorization web
the priv-lvl 15 attribute is being sent, but IP HTTP Auth fails.. any ideas why?
Update: Fixed it! I believe the access-enable autocommand was the cause!
Overall Rating: 5 (1 ratings)
Vivek Santuka Thu, 04/19/2007 - 05:46
I have seen that additional attributes such as "access-enable timeout 1920" would not allow http authentication to work with certain IOS versions.
