Night-service distinctive ring tone
Apr 18th, 2007
As per CCM admin guide the notified ephone will get distinctive ring tone but I got same tone in 'ephone 2' before & after the 'night-service' mode.
I saw a message 'File is not found distict...' on 'ephone 2' while notified. I cannot find any file in flash as name 'distint...' Is this related to the issue?
Advise please,
ephone-dn 1
number 1000
night-service bell
ephone-dn 2
number 1001
ephone 1
button 1:1
ephone 2
button 1:2
night-service bell
Paolo Bevilacqua Wed, 04/18/2007 - 06:17
  • Hall of Fame,
    Founding Member
the phone is looking for distinctiveringlist.xml, you must create the file, place it on the router in the tftp directory as well with the actual ringfiles you want for night-service.
Hope this helps, if so please rate post!
cjrchoi11 Wed, 04/18/2007 - 06:22
The CME admin guide didn't tell any about distinctiveringlist.xml file. Do I really need that file or able to achieve on CME4.0(2)?
Paolo Bevilacqua Wed, 04/18/2007 - 06:29
  • Hall of Fame,
    Founding Member
The CME guide sometime doesn't tell about a lot of things :)
Yes the file is required and you will need to enable it with "tftp-server" statement.
cjrchoi11 Wed, 04/18/2007 - 13:30
Okay, I downloaded the 'RingTone.tar' from CCO and changed the DistinctiveRingList.xml'
s 1st entry to 'Sax1.raw' but still I have same ring tone on 'ephone 2' before & after night-service.
what else do I need configure?
**Add the following in CME
tftp-server flash:DistinctiveRingList.xml
tftp-server flash:RingList.xml
tftp-server flash:Sax1.raw
Paolo Bevilacqua Wed, 04/18/2007 - 14:11
  • Hall of Fame,
    Founding Member
Hmmm... the tftp filenames are case sensitive.. Can you check with "debug tftp events" that the phone is actually getting the requested files ?
Is the message cone away on the phone ?
cjrchoi11 Thu, 04/19/2007 - 05:15
No tftp events when I dial the night target number 1000. follows my currnet environment. please advise what's wrong.
-2821, 12.4(11)XJ2
-CME 4.1(0)
Configuration
ephone-dn 1
number 1000
night-service bell
ephone-dn 2
number 1001
ephone 1
button 1:1
ephone 2
button 1:2
night-service bell
ccmelab#dir
Directory of flash:/
33 -rw- 489 Apr 18 2007 17:16:26 -05:00 DistinctiveRingList.xml
52 -rw- 495 Apr 18 2007 15:36:50 -05:00 RingList.xml
53 -rw- 10800 Apr 18 2007 15:36:50 -05:00 Sax1.raw
ccmelab#sh deb
TFTP:
TFTP Event debugging is on
TFTP Packet debugging is on
Paolo Bevilacqua Thu, 04/19/2007 - 05:47
  • Hall of Fame,
    Founding Member
Hi, which phone are you using? Is the night service displayed and active ?
I could to try this as well with CME 4.1
cjrchoi11 Thu, 04/19/2007 - 06:42
dial '1000' and the notificatoin to 'ephone 2' which associated to '1001' in my configuration. Yes, display on the IP phone 'Night Service Active'.
ephone 2 successfully rining the notification but the ring tone is same before & after 'Night Service' mode.
Paolo Bevilacqua Thu, 04/19/2007 - 06:43
  • Hall of Fame,
    Founding Member
Ok, which phone types ? I can try it with most types.
cjrchoi11 Thu, 04/19/2007 - 06:47
I'm testing with two 7960 and two IP communicator.
