Export the CSM's configuration to a new CSM
Apr 18th, 2007
Hi All,
I do need to export the configuration file from the CSM (in production) and upload it to a new CSM (lab environment) for testing purposes, the CSM serve only two FWSMs in active/standby mode.
In fact I have two concerns:
1. Is it possible to do what mentioned above, how?!
2. If the answer is YES, could I work with CSM and modify the configuration regardless of the physical connection to the FWSM (i.e physically the FWSM NOT connected to the CSM)!!
Appreciate the helpful comments..
Belal
Trending Topics - Security & Network
