VTP
Apr 18th, 2007
I have 3 switches 3750?s connected with Cat5 1000mb I need to set up Vlan?s. I?ve tried to set the vtp on one switch as master and the other two as client but when I create a vlan on the master switch I do not see any on the Client switches am I missing something?
ankbhasi Wed, 04/18/2007 - 07:03
Hi Friend,
Make sure you configure trunk between switches. Also make sure you have same VTP domain configured on all switches with same password.
I will recommed to first check the trunk connection between switches.
Ankur
ariela Wed, 04/18/2007 - 22:36
a very basic configuration that you have to do in your switches is like that:
conf t
vtp domain TEST (as you wish, but the same)
vtp mode server|client
vlan x
name X
vlan y
name Y
... (and so on)
interface (between switches)
switchport mode trunk
So, check your trunk, check your VTP configuration, and that's it.
Andrea
