L2-802.1x NAC Framework integration with Symantec
Apr 18th, 2007
Hi, I have trouble to integrate Symantec Antivirus to already running NAC Framework environment.
* Authentication using dot1x against Windows AD works
* CTA Posture Agent works
* Symantec ADF and Posture Plugin installed -- worked until Feb 2007, after that date stops
* Completely reinstalled ACS, imported ADF -- didn't help.
* Tried CTA 2.1, 2.0.1 without success.
* Tried remove ADF, import again, no success
Logs say that CTA is gathering Symc Posture informations well, but on the ACS nothing from Symantec is shown, but I can use them in policies, so ADF is imported correctly.
Server is ACS 4.1 build 23, PCs are Wins XPs and W2k, CTA 2.1 (I have properly set the PPMsg_size for Symantec to 1024).
Switches are 3550 (12.2.35SE) and 2950( 12.1.21EA8a).
Summary: I can't get postures from Symantec anymore, despite fact, that it worked in the past.
Can someone, who implemented Symantec AV in NAC Framework help me somehow?
One more question: what is the HCAP URL for Symantec Corporate AV server?
Thanks! Astib
didyap Tue, 04/24/2007 - 08:25
You need to install new Symantec Plugin files for CTA
astib Tue, 04/24/2007 - 09:07
Hi!
There are newer Sym Posture Plugins than on SAV 10.1 installation media? That's news for me, thanks! If so, can you please direct me where I can get them? I have seek through CDs, on Symantec Platinum, Google, ... but haven't found anything.
I would be glad for every information regarding Symantec HCAP Posture server; how to configure it on ACS in the External Posture Validation page?
Thank you very much!
