Ringtones for CCM 3.3.5
Apr 18th, 2007
Is there a place where I can download free ringtones for CCM 3.3.5 ?
Mojo1 Wed, 04/18/2007 - 12:09
I went and down loaded a ring tone and when I tried to access the ringtone.xml file I was not able to paste in the code for the ring tone. How are you able to add to the ringlist.xml file in CCM TFTP
Mojo1 Wed, 04/18/2007 - 12:50
I downloaded the flie to the TFTP Path in Call Manager. What I need to do it open the ringlist.xml file and be able to add to it with the
to the current list which I am not able to do. As I said the walkthisway.raw file is in the TFTP Path directory.
Mojo1 Wed, 04/18/2007 - 12:56
I also stopped and started the TFTP Service within CCM Serviceability, and when I look at the list of ring tones in the phone the walkthisway is not listed and in the ringlist.xml it is not listed as well. I just need to be able to edit the ringlist.xml and stop the start the serviceability to make it happen.
rob.huffman Wed, 04/18/2007 - 13:10
Hi Bill,
Use an ASCII editor to edit the RingList.xml file.(I'm pretty sure I have used Notepad)Don't forget to save the original before making any changes :)
Hope this helps!
