Monitor CPU Load/Menory/Temperature
alsayed
Hi Experts!
I have dome MRTG & I Created a cfg file VIA THIS COMMAND:
perl cfgmaker ALI@10.10.10.254 --global "WorkDir: c:\www\mrtg" --output mrtg.cfg
NOW Iwant to monitor the CPU The Temperature of the Access switches & CORE;WHAT The command should be to creat like this cfg for these issue
ALI
alsayed
Freinds!
any kind reply here!
regards
guruprasadr
Level 7
Level 7
HI,
Can you please post / attach the Configuration file of MRTG ie., CFG file.
Guru Prasad R
hello Guru!
# Created by
# cfgmaker ali@10.10.10.254 --global "WorkDir: c:\www\mrtg" --output mrtg.cfg
### Global Config Options
# for UNIX
# WorkDir: /home/http/mrtg
RunAsDaemon: yes
Refresh: 300
# or for NT
# WorkDir: c:\mrtgdata
### Global Defaults
# to get bits instead of bytes and graphs growing to the right
# Options[_]: growright, bits
EnableIPv6: no
# System: Switch
# Description: Cisco Internetwork Operating System Software
# IOS (tm) C3500XL Software (C3500XL-C3H2S-M), Version 12.0(5)XU, RELEASE SOFTWARE (fc1)
# Copyright (c) 1986-2000 by cisco Systems, Inc.
# Compiled Mon 03-Apr-00 17:31 by swati
# Contact:
# Location:
### Interface 1 >> Descr: 'VLAN1' | Name: 'VL10' | Ip: '' | Eth: '' ###
Target[10.10.10.254_1]: 1:ISIR@10.10.10.254:
SetEnv[10.10.10.254_1]: MRTG_INT_IP="" MRTG_INT_DESCR="VLAN10"
MaxBytes[10.10.10.254_1]: 1250000
Title[10.10.10.254_1]: Traffic Analysis for SWITCH
PageTop[10.10.10.254_1]:
System:
Switch in
Maintainer:
Description:
VLAN1
ifType:
ethernetCsmacd (6)
ifName:
VL1
Max Speed:
1250.0 kBytes/s
### Interface 2 >> Descr: 'FastEthernet0/1' | Name: 'Fa0/1' | Ip: '' | Eth: '00-02-b9-b8-c7-41' ###
### The following interface is commented out because:
### * it is operationally DOWN
# Target[10.10.10.254_2]: 2:ISIR@10.10.10.254:
# SetEnv[10.10.10.254_2]: MRTG_INT_IP="" MRTG_INT_DESCR="FastEthernet0/1"
# MaxBytes[10.10.10.254_2]: 75000000
# Title[10.10.10.254_2]: Traffic Analysis for 2 -- Switch
# PageTop[10.10.10.254_2]:
System:
Switch in
Maintainer:
Description:
FastEthernet0/1
ifType:
ethernetCsmacd (6)
HI alsayed,
Thanks for yor providing the Configuration. I have documentations for MRTG but its quiet difficult to understand & implement without any prior experience or guidance.
Can you please provide:
1.Complete MRTG Configuration file (Main file) for Windows / Unix
2.RRD Tool Integration
3.HTML Script for Webpage Display
4.Apache specifications for the Display.
Thanks in Advance for Help. You can remove your Company's Confidential.
Best Regards,
Guru Prasad R
